Solved Call Script - single department in Holliday
paulodagraca
3CX MVP
Platinum Partner
I do know, that there are some smart people here :)
Need some help with a script to set a single Department into Holliday mode.
There is a working demo script from 3CX, that will set ALL Departments at the same time:
https://www.3cx.com/blog/call-flow-scripts/force-pbx-hours/
However... how to set a single Department?
Below is the code that I did create... non working :(
The problem is to find the instance by name, and than use that instance to change the state or something like that (do not know) or use the Department number??
C#:
#nullable disable
using CallFlow;
using System;
using System.Threading.Tasks;
using TCX.Configuration;
using System.Linq;
using CallFlow.CFD;
using System.Collections.Generic;
namespace dummy
    public class ForceBreak : ScriptBase<ICall>
        public override async Task<bool> StartAsync()
            var ps = MyCall.PS as PhoneSystem;
            if(MyCall.Caller.DN is Extension && MyCall.ReferredByDN is null)
                string targetDepartmentNumber = "023";
                 //force office hours until midnight
                string targetDepartmentName = "MyDepartment";
                var targetDepartment = ps.GetAll<Group>()
                    .Where(x => x.Name.Equals(targetDepartmentName, StringComparison.OrdinalIgnoreCase))
                    .Extract(x => x.AllowCallService)
                    .FirstOrDefault();
                if (targetDepartment != null)
                    try
                        //force hiliday until midnight
                        var groupCurrentTime = targetDepartment.Now(out var utc, out var timezone, out var groupmode);
                        targetDepartment.OverrideExpiresAt = (groupCurrentTime + TimeSpan.FromDays(1)).Date;
                        targetDepartment.CurrentGroupHours = GroupHoursMode.ForceHoliday;
                        MyCall.Info($"{targetDepartment.Name} set to '{targetDepartment.CurrentGroupHours}' until {targetDepartment.OverrideExpiresAt}, timezone={timezone}, groupmode={groupmode}");
                        // Save the single department
                        targetDepartment.OMSave();
                        try
                            var result = await MyCall.AssureMedia()
                                .ContinueWith(_ => MyCall.PlayPrompt(null, [ "ST_OUTOFFICE_SET"], PlayPromptOptions.Blocked), TaskContinuationOptions.OnlyOnRanToCompletion)
                                .Unwrap();
                        catch
                            //nothing to report. changes are applied
                        return true;
                    catch
                        //just ignore it
                        return false;
                else
                    MyCall.Warn($"Department '{targetDepartmentNumber}' not found");
                    return false;
            return false;
Any help would be great :confused:
Paulo
Have you tried the set all departments to holiday mode call script, and then limit to department at the bottom? This may work, i havent tried this myself however.call script.png
Hello JoshWS,
Great, never seen the option in this combination.
Tested with Department selection from dropdown list, but it seems that all Department will go into 'Holiday mode' anyway's.
Script should be changed for this to work, i guess.
Paulo
Hi @paulodagraca
Replace Lines 22 to 29 with the following, and change XXXXX to the name of the department; note that it is case-sensitive.
if (x.Name is "XXXXX")
var groupCurrentTime = x.Now(out var utc, out var timezone, out var groupmode);
x.OverrideExpiresAt = (groupCurrentTime+TimeSpan.FromDays(1)).Date;
x.CurrentGroupHours = GroupHoursMode.ForceHoliday;
MyCall.Info($"{x.Name} set to '{x.CurrentGroupHours}' until {x.OverrideExpiresAt}, timezone={timezone}, groupmode={groupmode}");
return x;
Reactions: KyriacosS_3CX
mazet
