Call Statistic
Tulio
Forum User
want to generate an graphical weekly Call Statistic group by time (hours). Can't do that simple basic statistic. Do i something wrong or ist there no functiuon for that tiny statistic in the big and famous 3CX;-)
Cheers
Tulio
There's the reporting feature for this, on Pro and Enterprise.
Thanks for your reply. I'm not really surprised. The reporting function is just "cute". There is no way to do that with Pro. It really annoys me that I chose the 3CX product.
Hi Tulio,
If you can't get the information you need from the built-in 3CX Reports, you can create your own custom reports using the optional CDR files 3CX can create. The CDR files contain a lot of useful information. I personally configure 3CX to create a single file for each call. In the 3CX Management Console, navigate to Setting --> CDR. The CDR files are CSV files that can easily be parsed and placed in a database. You can then use whatever reporting tool you prefer to create your custom reports -- Excel, Crystal Reports, SQL Reporting Services, etc.
If you need even more detail, or you don't want to hassle with parsing the CDR files, I would encourage you to take a look at our 3CX Exporter tool. It can automate the entire process of getting access to all the same data 3CX uses to generate their built-in reports.
hughesdouglas
