Call Tagging
Cytranic
I'm trying to move a huge client over to 3cx. But one feature they really need is call tagging. When a customer calls a certain DID, they want the phone display to show "Google1" if the customer called a certain DID. Is this possible in 3cx? The reason for this is so they can tag the correct source in their CRM.
If you put the name 'Google1' on the inbound rule/ring group/queue it will prepend or append the name to the CID depending on the configuration.
You are the man
You will need to enable the option to prepend this, under Contacts / Options / Add Group, Queue or DID/DDI Names to Caller ID
RemyDijke
