Solved Call terminating on 2nd ring group
PIT-Admin
Hi, we have recently setup a new 3CX phone system. The main ring group is set for 10secs, then changes to the 2nd ring group (which has a 20sec ring time). This occurs as expected but only rings for 3 secs before terminating the call. Tried using mobile and landline numbers, same result.
08/05/2024 4:53:38 PM 04xxxxx1xxx RG Alternate (801) Unanswered 00:00:03 00:00:00 0.00 Terminated by 041xxxx1xxx
08/05/2024 4:53:27 PM 04xxxxx1xxx RG Main (800) Unanswered 00:00:11 00:00:00 0.00 No destinations, forwarded to RG Alternate (801)
Anyone know what is causing this?
Based on your trace, I calculate 10 seconds. I'm not certain I understand the details of your issue.
You mentioned that it only rings for 3 seconds before hanging up. Have you, by any chance, modified any global settings?
When you say “hangs up after 3 seconds”, is that after escalation?
Does any of the users , on RG 801 have the "ring my mobile simultaneously" feature enabled?
What should happen after RG 801? What is the next destination?
Hi Thanks for the reply.
  • Have not modified any global settings.
  • When you say “hangs up after 3 seconds”, is that after escalation?
    • The call is being terminated after 3 secs when it fails-over to the second ring group after the 10sec ring has completed
  • Does any of the users , on RG 801 have the "ring my mobile simultaneously" feature enabled?
    • No this feature is not enabled, no users have mobile's added ( there is a mobile in the call after hours in the main ring group)
  • What should happen after RG 801? What is the next destination?
    • RG 801 is set to ring for 20secs then fial-over to RG 802 which should ring for 20secs then end call
Here is a list of the structure
  • Main ring group (VEN 800)
    • 101 (reception)
      • Ring time 10Secs
        • Destination if no answer = Alternate ring group (VEN 801)
  • Alternate ring group (VEN 801)
    • 102 user
    • 103 Accounts
    • 104 Finance
      • Ring time 20secs
        • Destination if no answer = Others ring group (VEN 802)
  • Others ring group (VEN 802)
    • 105 user
    • 106 user
    • 107 user
    • 108 user
    • 109 user
    • 110 user
    • 111 user
      • Ring time 20secs
        • Destination if no answer = End Call
Is there an IVR before group 800?
Can you temporarily replace it with an IVR instead of RG 801 just for testing?
Hey mate, thanks for the help, found the culprit, our trunk had a setting with call set to 15secs
Good to know this is solved.
georgi
