Call
Lucamic
Receiving a call from the outside on the snom as the first line the name of the hunt group appears. Is it possible to modify this field for example by displaying the calling line?
First thing I do is make the name of the call que or ring groups very short, example: r1 or s1.
Second thing I do is mess with the settings in here till it looks ok, Sip trunks > trunk in question > Inbound parameters <tab> > Caller numbers/name field:
I find that
"CalledNum" number that has been dialed (default: To->user) : best with TO:user part
"CallerName" caller's name (default: From->display name) : best with FROM: Display Name
"CallerNum" caller's number (default: From->user) : FROM: user part
works ok with call que and snom phones.
see attached pic of incoming call.
You should also be able to choose to display the name before, or after the caller ID, or not at all.
Wecare_ITA
