Called ID on Emailed Voicemail
Michael R.
Hi, one of our client requested if we could convert the caller's number that is shown on voicemail emails.
Currently, its showing 61422200415, they want it to be just 0422200415
I tried playing around the reformat inbound caller ID but will that reflect on Email Template %%CALLER%%?
If yes, whats the correct source and replace pattern?
Most callers are in Australia so +61 can be just converted to 0 then add the rest.
Hello Michael R.,
Not sure about the email number, but I do remember one customer with this where the number was shown correct.
However you can add this, and check.
To Reformat inbound caller Caller ID:
Use this line:
Source Pattern 61(.*) - Replace Pattern 0\1
You can also add these extra lines
Source Pattern 0061(.*) - Replace Pattern 0\1
Source Pattern +61(.*) - Replace Pattern 0\1
Paulo
Reactions: KyriacosS_3CX
Thanks Paulo! Let me try those and see if it will also reflect on the email message.
tom.walker@blackcountryra
