Caller ID Prefixing on Call Queues
kriley87
Is there a way to prefix the inbound caller ID on calls coming into various call queues?
EX: If someone calls and presses 1 for customer service, the caller ID is prefixed with CS: 9724444444
EX: If someone calls and press 2 for sales, the caller ID is prefixed with SALES: 9724444444
We are needing this ability as we have people who are members of multiple call queues and need to know which queue a call is coming in from so that they answer the phone properly.
Thank you!
Hi @kriley87
Can you tell me what type of phones you use, and your trunk's Inbound Parameters in the "Caller Number/Name Field Mapping" drop down lists?
Good morning!
This customer in particular uses a mix of Grandstream (1628, 2130, 2135, etc.) and Yealink (T41, T42, T46).... so, they really don't have a standard sadly.
As far as the inbound parameters for my trunk:
Caller Name > From: DisplayName
Caller Number > From: UserPart
Our provider is Bandwidth if that helps.
is this what you are looking for?
11596
I don't think so. Correct me if I'm wrong but that just prepend's a name on an incoming caller ID for a DID that is listed in the Contacts section of 3CX.
We are looking to prepend calls coming in to specific call queues.
no , try it
title in capture isn't clear enough
11597
Reactions: kriley87
You might have to switch your "CallerName" -> From: User part
Or take a quick capture from an incoming call, and see where you provider sends it so you can adjust accordingly
Thanks John -- I will give this a try and try aws2p's suggestion of prepending queue name's in the contact options.
I can confirm that it shows you the name of any Q, RG or DID :)
Reactions: kriley87
[email protected].
