Caller ID when phone can receive multiple calls and already on the phone
colonial
Gold Partner
Is there a way to get caller id info to come through on the 2nd call when an extension can receive multiple calls and they are already on one call?
It should already? What phones are you using? Might be a phone setting or limitation?
I use Grandstream's and I get the caller ID when a second line is coming in.
Yealink t46s t46g ... dont see caller id on 2nd caller
Are you using the default template after factory reset?
Also, is the second call private? It would explain why it doesn't show up.
yes default template
private call ... no just another caller
my clients 3cx and my office 3cx same behavior (doesnt show up)
we are going to look through yealink gui for any clues
Factory reset one phone then reprovision. See if it comes back (sometimes, certain settings might stay and cause problem).
hughesdouglas
