Unsupported Caller is forbidden on ringgroup
NoFate
SMB User
Hey
I'm testing a 3cx on premise install, all is working, fine
extension 3000 = door intercom
extension 3001 = sip client
extension 3002 = sip client
ringgroup 3100 type ring all, containing members 3001 and 3002
from 3000 i can call to 3001 or 3002 , all working OK! But i had first always the error 603 decline, caller is forbidden (also when i did a call to 3001 or 3002)
Its all internal on local subnet, no fqdn , enabled SIP calls, and the most important feature, i had to enable this option below to make the 603 error go away ...
Under Users => options => options => SIP ID , i put there for every extension the ID again, so for 3000 i put there 3000 , then the error went away
now, i want to test ringgroups
but i then have again the 603, caller is forbidden... so how can i enable that SIP ID on a ring group? or how can i fix this issue?
thnx
below is log
Code:
INVITE sip:[email protected]:5060 SIP/2.0
Max-Forwards: 20
Via: SIP/2.0/UDP 192.168.0.70:5060;rport;branch=z9hG4bK533295590
From: "3000" <sip:[email protected]>;tag=1020907903
To: <sip:[email protected]:5060>
Call-ID: [email protected]
CSeq: 232 INVITE
User-Agent: YATE/5.5.0
Contact: <sip:[email protected]:5060>
Allow: ACK, INVITE, BYE, CANCEL, MESSAGE, OPTIONS, INFO
Content-Type: application/sdp
Content-Length: 288
v=0
o=yate 1634251910 1634251910 IN IP4 192.168.0.70
s=SIP Call
c=IN IP4 192.168.0.70
t=0 0
m=audio 9654 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
m=video 9856 RTP/AVP 96
a=rtpmap:96 H264/90000
a=fmtp:96 profile-level-id=4D001F; packetization-mode=1
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP 192.168.0.70:5060;rport=5060;branch=z9hG4bK533295590
Proxy-Authenticate: Digest nonce="414d53596168986723:708b9cdda529793c9bd6a9b01b850289",algorithm=MD5,realm="3CXPhoneSystem"
To: <sip:[email protected]:5060>;tag=6508fb11
CSeq: 232 INVITE
Content-Length: 0
ACK sip:[email protected]:5060 SIP/2.0
CSeq: 232 ACK
Max-Forwards: 20
Content-Length: 0
Max-Forwards: 20
Via: SIP/2.0/UDP 192.168.0.70:5060;rport;branch=z9hG4bK2103115691
CSeq: 233 INVITE
Proxy-Authorization: Digest username="3000", realm="3CXPhoneSystem", nonce="414d53596168986723:708b9cdda529793c9bd6a9b01b850289", uri="sip:[email protected]:5060", response="9bf230af6b4501ebacf8b7dfb10d5578", algorithm=MD5
Content-Length: 288
v=0
s=SIP Call
t=0 0
SIP/2.0 603 Decline
Via: SIP/2.0/UDP 192.168.0.70:5060;rport=5060;branch=z9hG4bK2103115691
To: <sip:[email protected]:5060>;tag=132da303
CSeq: 233 INVITE
Warning: 499 debian "Caller is forbidden"
Content-Length: 0
CSeq: 233 ACK
Max-Forwards: 20
Content-Length: 0
HI @NoFate
Add a 3CX client to all your extensions and make calls between them and see if that works so we can rule a few staff out. Try that even without the SIP IDs to see if everything works and let us know.
yeah, tried that before too, was the same message/error
Did you replace everything with 3CX clients?
Can you give us some more details regarding the PBX and your network? Also does *777 work from a 3CX client?
yeah, that was my first setup, all with 3cx clients, same issue
my setup , all is local (on premise)
pbx = ip 192.168.0.155
doorstation where i call from = ip 192.168.0.70
setup doorstatio (sip setup) is on direct IP
so i setup 192.168.0.155:5060 :> with extension username and password
there is no domain option to configure
so in network setup of 3cx , in the domain field, i have entered there the PBX ip = 192.168.0.155
so all is local setup
Did you replace the doorstation as well with a 3CX client for a test? Also what version PBX are you running?
From the logs you provided it looks like the authentication is failing when making a call like the PBX does not recognize the caller which should not happen if you are using 3CX clients which were auto provisioned so that is strange.
Did you try the *777 test with a 3CX client?
i can try later to call with *777, not at home
with 3cx clients or softphone clients, i can call to ringgroup, thats no issue then
its just from this specific doorstation, thats givinc me headaches, i can call to ringgroups
btw, is also early media (video before accepting) call, supported on ring groups?
it works if i just call an extensions
thnx
Ok now we are getting somewhere. So if its the door phone that is giving you issues then that makes more sense because for a 3CX extension to register you need 3 things. You need the extension number the Auth ID and the password. If your door phone does not have the 3 options then you might run into issues and may need to find another solution.
No this is not supported.
Ok, no ring group support , allthough I saw earlier some people mentioning it should work... Gonna test it out, if I can clear this issue
Indeed , i can only enter username and password on doorstation, but it works when I call single extensions from it, it just doesn't work when I call a ring group...
Could be the network/domain be an issue? I can try maybe the hosted 3cx , so it's all based on fqdn ?
You mentioned this only working if you add a SIP ID under the extensions. Is that not the case?
I don't think this will make any difference.
yes, calling to other sip clients, ONLY works when i add a SIP ID , indeed
why is that anyway ?
I suspect is because when dealing with direct SIP calls (which is what the SIP ID is meant for) there is no authentication which comes back to the calling extension not being able to authenticate properly.
i know testing the 3cx cloud instance , to rule out network/domain
doorstation sip 3000 , sip client = 3002
unchecked the option "disallow use extension outside lan"
so 3000 and 3002 are registered fine...
but when i call from doorstation to sip, i get a 603 decline, caller is forbidden...
even if i enable the direct SIP ID
pfff, frustating
Code:
Max-Forwards: 20
Via: SIP/2.0/UDP 99.999.120.10:5060;rport;branch=z9hG4bK1164939144
From: "3000" <sip:[email protected]:5060>;tag=493874600
CSeq: 254 INVITE
Content-Length: 290
v=0
o=yate 1634302555 1634302555 IN IP4 99.999.120.10
s=SIP Call
c=IN IP4 99.999.120.10
t=0 0
Via: SIP/2.0/UDP 99.999.120.10:5060;rport=5060;branch=z9hG4bK1164939144
Proxy-Authenticate: Digest nonce="414d535961695e3b60:b1bd6b4cdbeca89d22c414769e2f6fed",algorithm=MD5,realm="3CXPhoneSystem"
To: <sip:[email protected]:5060>;tag=c37fc272
CSeq: 254 INVITE
Content-Length: 0
CSeq: 254 ACK
Max-Forwards: 20
Content-Length: 0
Max-Forwards: 20
Via: SIP/2.0/UDP 99.999.120.10:5060;rport;branch=z9hG4bK1390535221
CSeq: 255 INVITE
Proxy-Authorization: Digest username="3000", realm="3CXPhoneSystem", nonce="414d535961695e3b60:b1bd6b4cdbeca89d22c414769e2f6fed", uri="sip:[email protected]:5060", response="8b4a1c7ba10510eb9d0cf5dd7bba5a8d", algorithm=MD5
Content-Length: 290
v=0
s=SIP Call
t=0 0
SIP/2.0 603 Decline
Via: SIP/2.0/UDP 99.999.120.10:5060;rport=5060;branch=z9hG4bK1390535221
To: <sip:[email protected]:5060>;tag=d5987f72
From: "3000"<sip:[email protected]:5060>;tag=493874600
CSeq: 255 INVITE
Warning: 499 xxxx "Caller is forbidden"
Content-Length: 0
CSeq: 255 ACK
Max-Forwards: 20
Content-Length: 0
I believe its like before. Call comes in the PBX asks for authentication which the fails and you get a 603 decline. Since this is an unsupported device you will need to either use a supported device or figure out a way to have it authenticate properly. Not a lot we can do here I am afraid.
Reactions: JohnS_3CX
hmm, thats not possible for me, its an hikvision door intercom, its not something i can replace :-)
dont get it why 3cx is bugging me, it works on freepbx and also on freeswitch
why not on 3cx ?
hmm, thats not possible for me, its an hikvision door intercom, its not something i can replace :)
why not on 3cx ?
Since this is not a supported device, if you still wish to use it you will have to debug it yourself or get help directly from the manufacturer.
We do not provide assistance for unsupported devices as made clear here
https://www.3cx.com/community/threa...-phone-how-can-i-make-it-work-with-3cx.84739/
i understand, but its 3cx thats rejecting the calls ? :-)
isnt there a setting somewhere to allow the calls?
allthough, the latest log 2 replies earlier, the error is different tough, i see now a 499 , caller is forbidden
it was before i 607 i believe...
so maybe there is a setting i'm missing in 3cx cloud to allow the caller?
Zexus
