CallFlow 15.5 SP6
Konni
Hello after the update to latest SP6 build, the callers didn't hearing any announcement from the call flows.
It's just a crack to hear, the callflows were also re-uploaded, but no announce.
Same callflows working with the Version SP5 without any problems.
Hello @Konni
Are you referring to queues, digital receptionists, music on hold or were you using the call flow designer to create your call flows?
I used the call flow designer.
I think I have detected the problem.
I builded the Voiceapp from scratch, it works until I add a Record and eMail function, without, the voiceapp is working.
I think there is a bug in the SP6.
In that case i would recommend posting the issue in our dedicated Call Flow Designer forum section where the issue can be examined by the appropriate team
https://www.3cx.com/community/forums/call-flow-designer.63/
