Calls drops when transferring to mobile phone
totaycs
Hi all,
We’re running 3CX v20 with an AAPT SIP trunk. Direct outbound calls to mobiles and landlines work fine.
From SIP logs:
Direct mobile dial = works.
Transfer to mobile = fails. 3CX sends a BYE (UserTerminated) shortly after.
What I’ve done so far:
Checked outbound rules → mobiles route correctly.
Verified in the exported trunk XML that IsSupportReinvite=0 and IsSupportReplaces=0.
Anyone have similar issue?
Blind transfer or attended?
How many SC you got?
Could the issue be the caller ID , being sent, when doing a transfer? Check the 3CX Activity log to see if your provider is rejecting the call , for that reason. Different transfer types send different caller ID, you may be trying to send the CID of the extension.
Roman Mazur
