Calls losing audio after 30mins
prolateral
Since Version 20.0 Update 10 (Build 1801 Release - AI 1.6.91) was installed a week past Sunday, we have started experiencing call-audio being dropped after 30mins.
Call remains connected - but audio is lost completely on exactly 30mins. It was not happening at all prior to the update above.
It is the same on internal calls and external calls -- but internal calls connected via the same SBC seem to be fine.
It is occuring on both our self-hosted installs with and without firewalls, with sites running SBC v20.0.100 - but they were previously running SBC v18 without issue. We updated all SBCs to see if that was the issue - but neither that, nor reprovisioning our SNOMs, nor factory resets have resolved it.
What information is best to capture in order to narrow down the problem? Is anyone else having the same issue?
So, you have the same issue with the internal calls too or is ist explicit to external calls? could you please check that user extensions have enabled the parameter pbx delivers audio within the options tab.
Also, if you use only the 3CX APPs with an internal call do you have the same issue or is it related to deskphones only?
What phones are you using, are these with the default template and recommended firmware?
What is the firewall checker result?
how many deskphones are behind the 3cx sbc and its hardware specs?
opengates
