Can’t Find Available / DND Autoswitch
wraight.it.services
I think I’m going crazy. I’ve been using a feature for ages for a customer but now I can’t seem to find ‘Autoswitch’. I’ve looked under ‘Users > User > Forwarding Rules’ as per a couple of threads. But I just can’t see it. Please help?
JW
Hello @wraight.it.services,
Open your Webclient -> Go to settings -> Status -> Status Scheduler:
Hiya, so has this been moved then? I seem to remember it being in the management console under the extension before? Is there any way to do this from the management console still? Without logging into the WebClient as each user?
Yes,
That has been moved from the management console.
You need to access the WebClient of each user in order to change the status.
VR46
