Can I send some ring group calls straight to VM?
Rylen
SOHO User
I've got a home install of 3CX free. We have several phones per person in different parts of the house. I handle that by having a ring group ring all of a persons extensions. So far, everything normal.
I've been asked if I can have calls to that person/DID go straight to VM if any of that ring groups extensions are in use.
Example: DID1 goes to Group1 and then Extensions 101, 102, and 103, going to VM1 if nobody picks up. Is it possible to, if 102 is in use, send DID1 to VM1 bypassing ringing the extensions?
Thanks for the help.
AFAIK no, because the other extensions are not in use, and ring-able. You could set them all up as phones on the same extension though...?
I was not aware that was an option. I'll look into how that works.
Thanks.
LeeonLau
