Can make outgoing calls from soft phone, but not Granstream HT801.
Atr3id3s
New User
My apologies I'm a bit of a newbie here and trying to teach myself.
I've got the Outbound rules set and I can make and receive calls from the softphone (iOS app), but having just provisioned a Granstream HT801 ATA, I can receive calls, and call between extensions, but cannot complete an outbound call.
Hopefully someone can point me in the right direction.
Code:
03/14/2023 4:50:52 PM - [CM504004]: Registration succeeded for: Lc:10000(@VoIP.MS[<sip:[email protected]:5060/UDP>])
03/14/2023 4:50:52 PM - Leg L:5.1[Extn:15] is terminated: Cause: BYE from PBX
03/14/2023 4:50:52 PM - [CM503020]: Call(C:5): Normal call termination. Call originator: Extn:15. Reason: Server Failure
03/14/2023 4:50:52 PM - L:5.1[Extn:15] failed to reach Line:10000>>2********9, reason Server Failure
03/14/2023 4:50:52 PM - Leg L:5.2[Line:10000>>2********9] is terminated: Cause: 503 Service Unavailable/INVITE from 208.100.60.61:5060
03/14/2023 4:50:52 PM - Call to T:Line:10000>>2********9@[Dev:sip:[email protected]:5060] from L:5.1[Extn:15] failed, cause: Cause: 503 Service Unavailable/INVITE from 208.100.60.61:5060
03/14/2023 4:50:52 PM - [CM503003]: Call(C:5): Call to "REDACTED" <sip:2********[email protected]:5060> has failed; Cause: 503 Service Unavailable/INVITE from 208.100.60.61:5060
03/14/2023 4:50:52 PM - [CM503025]: Call(C:5): Calling T:Line:10000>>2********9@[Dev:sip:[email protected]:5060] for L:5.1[Extn:15]
03/14/2023 4:50:52 PM - [CM503027]: Call(C:5): From: Extn:15 ("REDACTED" <sip:[email protected]:0>)  to  T:Line:10000>>2********9@[Dev:sip:[email protected]:5060]
03/14/2023 4:50:52 PM - [CM503004]: Call(C:5): Route 1: from L:5.1[Extn:15] to T:Line:10000>>2********9@[Dev:sip:[email protected]:5060]
03/14/2023 4:50:52 PM - Line limit check: Current # of calls for line Lc:10000(@VoIP.MS[<sip:[email protected]:5060/UDP>]) is 0; limit is 10
03/14/2023 4:50:52 PM - Call(C:5): Call from Extn:15 to 2********9 matches outbound rule 'Outgoing Calls (DECT)'
03/14/2023 4:50:52 PM - [Flow] Call(C:5): has built target endpoint: Out#:>>Rule{Outgoing Calls (DECT)}>>2********9 for call from L:5.1[Extn:15]
03/14/2023 4:50:52 PM - [Flow] Target endpoint for 2********9 is Out#:>>Rule{Outgoing Calls (DECT)}>>2********9
03/14/2023 4:50:52 PM - [CM503010]: Call(C:5): Making route(s) from Extn:15 to <sip:2********[email protected]:0/UDP>
03/14/2023 4:50:52 PM - [CM505001]: Endpoint Extn:15: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream HT801 1.0.41.5 C074ADBA116B] PBX contact: [sip:[email protected]:5060]
03/14/2023 4:50:52 PM - [CM500002]: Call(C:5): Info on incoming INVITE from Extn:15:
Invite-IN Recv Req INVITE from 10.10.10.52:5060 tid=676386225 [email protected]:
INVITE sip:2********[email protected] SIP/2.0
Via: SIP/2.0/UDP 10.10.10.52:5060;branch=z9hG4bK676386225;rport=5060
Max-Forwards: 70
Contact: "REDACTED" <sip:[email protected]:5060>
To: <sip:2********[email protected]>
From: "REDACTED"<sip:[email protected]>;tag=425549165
Call-ID: [email protected]
CSeq: 131 INVITE
Accept: application/sdp, application/dtmf-relay
Allow: INVITE, ACK, OPTIONS, CANCEL, BYE, SUBSCRIBE, NOTIFY, INFO, REFER, UPDATE
Content-Type: application/sdp
Proxy-Authorization: Digest username="REDACTED",realm="3CXPhoneSystem",nonce="414d53596411085b97:fc9773bbd93237381377e571e0b5a32b",uri="sip:2********[email protected]",response="0490727b503ef1705f6cda88c32b3da8",algorithm=MD5
Supported: replaces, path, timer, eventlist
User-Agent: Grandstream HT801 1.0.41.5 C074ADBA116B
Privacy: none
P-Preferred-Identity: "REDACTED" <sip:[email protected]>
P-Access-Network-Info: IEEE-EUI-48;eui-48-addr=70-A7-41-A6-A4-0F
P-Emergency-Info: IEEE-EUI-48;eui-48-addr=C0-74-AD-BA-11-6B
Content-Length: 448
v=0
o=15 8000 8000 IN IP4 10.10.10.52
s=SIP Call
c=IN IP4 10.10.10.52
t=0 0
m=audio 5004 RTP/AVP 0 8 18 2 97 120 9 101
a=sendrecv
a=rtpmap:0 PCMU/8000
a=ptime:20
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:2 G726-32/8000
a=rtpmap:97 iLBC/8000
a=fmtp:97 mode=20
a=rtpmap:120 opus/48000/2
a=fmtp:120 maxplaybackrate=16000
a=rtpmap:9 G722/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16,32-36,54
03/14/2023 4:50:52 PM - [CM503001]: Call(C:5): Incoming call from Extn:15 to <sip:2********[email protected]:0>
The provided log file shows only the Invite from the Grandstream to the external number. Can you please clarify if a valid outbound rules has been configured?
I think so but I'm very new to this so it's likely something very simple that I missed. When I make outgoing calls in general it works, just not with the phone with the ATA adapter. To be clear it's the first physical piece of hardware I've attached to the system, all other calls I've made were with the 3CX soft phone, which can both send and receive calls.
Yes I've followed the document.
FW v. 1.0.43.11
This is the error when I make a call from the ATA:
Code:
03/15/2023 2:42:06 PM - Leg L:7.1[Extn:15] is terminated: Cause: BYE from PBX
03/15/2023 2:42:06 PM - [CM503020]: Call(C:7): Normal call termination. Call originator: Extn:15. Reason: Server Failure
03/15/2023 2:42:06 PM - L:7.1[Extn:15] failed to reach Line:10000>>2********9, reason Server Failure
03/15/2023 2:42:06 PM - Leg L:7.2[Line:10000>>2********9] is terminated: Cause: 503 Service Unavailable/INVITE from 208.100.60.61:5060
03/15/2023 2:42:06 PM - Call to T:Line:10000>>2********9@[Dev:sip:[email protected]:5060] from L:7.1[Extn:15] failed, cause: Cause: 503 Service Unavailable/INVITE from 208.100.60.61:5060
03/15/2023 2:42:06 PM - [CM503003]: Call(C:7): Call to "M******S" <sip:2********[email protected]:5060> has failed; Cause: 503 Service Unavailable/INVITE from 208.100.60.61:5060
03/15/2023 2:42:06 PM - [CM503025]: Call(C:7): Calling T:Line:10000>>2********9@[Dev:sip:[email protected]:5060] for L:7.1[Extn:15]
imelda
