Can NOT set TIME ZONE ( Object reference not set to an instance of an object )
Chris Rizzuto
Greetings all,
I posted this in March but have not had any help suggestions....
My 3CX instance has NO TIME ZONE set. When I try to set a time zone, I try to pick it from the list of zones and then hit OK.
I immediately get the following error:
Object reference not set to an instance of an object.
  • 3CX Version, Standard Annual 16.0.619
  • Hosted with Ixica
  • Are custom Phone Templates being used: YES
Any thoughts?
Cheers,
Chris
Globally on the PBX or extension specific?
Can you try it on an extension using default template?
bosdorf
