Can only answer one incoming call at a time
netservuk19
Forum User
Just had an issue with 3CX 15.5.15502.6 where you can pick up the first incoming call with no issues
When a second call comes in all the phones ring, but when you pick up the call you get the queue hold music. After several reboots of the PBX PC, handsets and routers, the issue still remains.
My 3CX PBX is running on Windows 10
In the end I removed KB4494441 Cumulative Update 2019-05
After a restart my PBX started to function correctly
HTH
Jim
Reactions: AWS2P
Thanks for sharing , may help others
Microsoft said:
To check if KB4494441 is installed correctly on your device, just check the version number of your Windows 10. To do this just run winver.exe in Run (WIN + R). If the number 17763.503 appears, everything worked out well.
hughesdouglas
