Can RaspberryPI config be ported into a Debian Intel PC?
k.lee
Forum User
I've got a working 3CX configuration working in a RaspberryPI.
Is it possible to port the configuration into an Intel PC running Debian?
I would like to understand the differences of running 3CX in the 2 different platforms.
thx
Kenneth
Yes.
The primary difference is Pi is no longer supported after 18u3 I believe it was.(except as an SBC)
Thx so much for confirming. I'll give it a go and try it out.
U mean that I can restore my Raspberry PI config into a 3CX hosted/startup instances as well? Wow! That's awesome compatibility between platforms. It'll give users so much options for migration to different platforms as their requirements change. I'll go check it out. Thx!
Reactions: TheodorosG_3CX
@k.lee Yes, migrate and restore your backup to 3CX Hosted will be the best for you. The machine will always be up to date and the 3CX Team will monitor the system for you.
asandris
