Cannot activate after backup restore
alexstr
Hi.
I just moved from a self hosted Pi4 deployment to a self hosted Windows deployment.
After restoring the backup i'm getting this error:
3CX failed to establish a TCP connection to activate.3cx.com.
Ensure that the local or border firewalls are configured to allow outbound traffic to activate.3cx.com
The thing is I cannot ping that domain from anywhere in the world.
Anyone knows why?
Thanks.
Alex
You should allow external traffic from PBX to :
activate.3cx.com
downloads-global.3cx.com,
sip-alg-detector.3cx.com
customer.3cx.com
smtp-proxy.3cx.net
wmr.3cx.net
qos.3cx.net
ping activate.3cx.com should provide an answer to you.
What is the exact version of the PBX ?
Hi.
Raspi version was 18.0 Update 2
Windows version is the latest 18.0 Update 5 build 418
here is the output from the machine:
C:\Users\pbx>nslookup activate.3cx.com
Server: dns.google
Address: 8.8.8.8
Non-authoritative answer:
Addresses: 2606:4700::6812:f36
2606:4700::6812:e36
104.18.14.54
104.18.15.54
C:\Users\pbx>ping activate.3cx.com
Pinging activate.3cx.com [104.18.14.54] with 32 bytes of data:
Reply from 104.18.14.54: bytes=32 time=125ms TTL=56
Ping statistics for 104.18.14.54:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 125ms, Maximum = 125ms, Average = 125ms
Server: dns.google
Address: 8.8.8.8
2606:4700::6812:e36
104.18.15.54
104.18.14.54
Server: dns.google
Address: 8.8.8.8
2606:4700::6812:e36
104.18.14.54
104.18.15.54
Server: dns.google
Address: 8.8.8.8
2606:4700::6812:e36
104.18.15.54
104.18.14.54
Reply from 104.18.14.54: bytes=32 time=127ms TTL=56
Reply from 104.18.14.54: bytes=32 time=124ms TTL=56
Minimum = 124ms, Maximum = 127ms, Average = 125ms
C:\Users\pbx>ping downloads-global.3cx.com
Pinging downloads-global.3cx.com [104.18.14.54] with 32 bytes of data:
Minimum = 124ms, Maximum = 125ms, Average = 124ms
C:\Users\pbx>ping sip-alg-detector.3cx.com
Pinging sip-alg-detector.3cx.com [34.141.156.185] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 34.141.156.185:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\Users\pbx>ping customer.3cx.com
Pinging customer.3cx.com [104.18.15.54] with 32 bytes of data:
Reply from 104.18.15.54: bytes=32 time=130ms TTL=56
Reply from 104.18.15.54: bytes=32 time=128ms TTL=56
Reply from 104.18.15.54: bytes=32 time=127ms TTL=56
Ping statistics for 104.18.15.54:
Minimum = 127ms, Maximum = 130ms, Average = 128ms
C:\Users\pbx>ping smtp-proxy.3cx.net
Pinging smtp-proxy.3cx.net [35.188.171.116] with 32 bytes of data:
Reply from 35.188.171.116: bytes=32 time=216ms TTL=58
Reply from 35.188.171.116: bytes=32 time=213ms TTL=58
Ping statistics for 35.188.171.116:
Minimum = 213ms, Maximum = 216ms, Average = 213ms
C:\Users\pbx>ping wmr.3cx.net
Pinging ghs.googlehosted.com [216.58.208.243] with 32 bytes of data:
Reply from 216.58.208.243: bytes=32 time=8ms TTL=59
Reply from 216.58.208.243: bytes=32 time=6ms TTL=59
Ping statistics for 216.58.208.243:
Minimum = 6ms, Maximum = 8ms, Average = 6ms
C:\Users\pbx>ping qos.3cx.net
Pinging qos.3cx.net [68.183.8.11] with 32 bytes of data:
Reply from 68.183.8.11: bytes=32 time=134ms TTL=54
Reply from 68.183.8.11: bytes=32 time=128ms TTL=54
Ping statistics for 68.183.8.11:
Minimum = 128ms, Maximum = 134ms, Average = 129ms
Server: dns.google
Address: 8.8.8.8
2606:4700::6812:e36
104.18.15.54
104.18.14.54
Reply from 104.18.14.54: bytes=32 time=126ms TTL=56
Minimum = 124ms, Maximum = 126ms, Average = 124ms
C:\Users\pbx>
Also the error in the log is:
Load license has failed, error: 5
In management console 3cx >> Dashboard >> License and click on "Refresh License Key,
Do you get an error?
Can you send me by private message your license please ?
PM sent.
Refresh license key gives me the same error
Thanks,
Test from pbx to see if activate.3cx.com is reachable :
- (Windows) from a URL web page try
https://activate.3cx.com
If OK: should get a blank page
- (Debian) in ssh/root try :
wget https://activate.3cx.com
If OK: should get: 200 OK
Be sure to use primary/secondary DNS 8.8.8.8/8.8.4.4
A capture wireshark can be run from admin console 3CX on refresh license.
In the capture filter by "DNS" to see which dns is used.
You can also open a ticket to 3cx support from your portal (https://portal.3cx.com/login).
Hi all.
Just an update on my issue.
I reinstalled windows 10 on the machine many times with the same result: activation failed.
Then I installed Debian10. Initially I got some issues because of the Broadcom driver, but all fixed and behold: activation is done.
I guess the Windows 10 22H2 has some weird issues with 3CX. Didn't want to dig deeper because the issue is solved for me.
Thanks.
