Cannot Get 3CX To Work with Zoho CRM
TacticalTechAdministrator
Every time I try to get my Zoho CRM to connect to my 3CX It gives me an Error that It cannot connect and then when I try to authorize a Token it just sends me to a page that says "
Invalid Redirect Uri
Redirect URI passed does not match with the one configured"
Is there any way I could Resolve this?
Yes, this is because the Redirect URI that you specified when you created the Client ID in Zoho is not matching the Redirect URI specified by 3CX when doing the authorization. 3CX will send to Zoho the Redirect URI built from the Console URL that you're using during authorization, so please ensure that both match.
If you're not sure, tell me which Redirect URI you specified when you created the Client ID in Zoho, and which is the URL in your browser when you're accessing the console to do the authorization.
You probably have to change to the EU domains in the 3CX CRM Integration screen, it looks like you're not on the .com namespaces.After selecting Zoho as CRM, change .com to .eu
https://accounts.zoho.eu
https://crm.zoho.eu
Hope that helps!
Reactions: fiurino
skander
