Cannot get phones to register
JRam
Trainee Partner
I have tried both Fanvil and yealinks. I set up the phone via autoprovisioning but they fail. I can see a multi cast SIP going out to 224.0.1.75 but there is nothing in return. can anyone explain what should happen when we try to register phones?
3CX Version, Professional Annual 16.0.641
Server OS, Lightsail using Debian
Is the 3CX Server Hosted and where? Lighsail
IP Phone Make/Model/Firmware Fanvil X4G 2.0.3.3049 also used Yealink t20 and same issues
Provisioning Method: Local / VPN / STUN / SBC Tried both local and stun
Trunk Provider or Gateway Make/Model Voicehost
Has the Firewall Checker passed: YES / NO yes
Are custom Phone Templates being used: YES / NO no
I definitely had this working vis Local, but now when reading the guides it appears that this can only be used when you have a local 3cx server or an SBC. If that was so how did it work in the first place.
Anyway. It appears that I can only provision this using STUN?
Local will not work if your PBX is in the Cloud and the phone is in some other remote location.
Only a site-to-site VPN would allow it to work properly in LAN mode
- OR an SBC
- OR STUN mode
[email protected].
