Solved Cannot remove phone to provision to another user
prairie
One of my users had 3 phones provisioned to them. One Softphone and 2 Yealink 48S. The problem is that the MAC addresses for the 48S appear to be the same for two different physical phones. They show they have two different IP addresses. I tried deleting the phone from the user based on the MAC address on the bottom of the phone and the IP address. I cannot seem to be able to re provision to another user for love nor money. Please assist.
Hello @prairie
That is a visual issue of the management console that causes the phones to appear with the same MAC address when 2 identical phones are provisioned under the same extension.
Since you deleted the right on there should be no problem assigning it to a different extension.
Are the phones local or remote to the server? Was the phone factory reset? If the phone is local or through SBC do you see it as a new phone under the phones tab? What version PBX are you running?
I have the latest 15.5. I hit the reprovision button and it fixed it. It is deployed across our VPN.
Glad to see the issue has been resolved and thank you for updating the thread with your solution.
Mr_IT
