- Joined
- Jul 22, 2020
- Messages
- 12
- Reaction score
- 2
I have the issue that at random times some users cannot search the addressbook within the 3cx Windows App. Nothing is shown.
App log shows:
Error event caught, Cannot send request: RequestLookupContact, channel [ 41930743 with https://3cx.domain.com:5001/myphone/MPWebService.asmx ]
System.InvalidOperationException: Request RequestLookupContact cannot be sent without logging in
bei MyPhoneClientChannelNet.Implementation.ClientChannelImpl.CheckLoggedIn(IExtensible request, IExtensible response)
bei MyPhoneClientChannelNet.Implementation.ClientChannelImpl.<doRequestAsync>d__68.MoveNext()
--- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde ---
bei System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
bei MyPhoneClientChannelNet.Implementation.ClientChannelImpl.<RequestAsync>d__67.MoveNext()
As said, it happens randomly, and only some users experience it. An app restart fixes the Problem.
Server Version is 16.0.5.619 on Debian 9.
Client Version is 16.3.0.144 on Windows 10.
We use Avast Business AV/FW.
Users work through VPN (Cisco AnyConnect with SSL Tunneling and Cisco ASA FW) from home, 3cx connection is also going through the vpn tunnel, we need to keep it this way.
Firewall-Check in 3CX Management Console is green.
All the best,
Ivan.
App log shows:
All the best,
Ivan.
