Solved Cant access WebUI running on Raspberry Pi 3 b+
GeeF0rce
Hi there!
I am completely new to 3CX so please go easy on me.
I have successfully installed 3CX on a Raspberry Pi 3 b+.
Setup my FQDN, Username, PW etc.
The installation and configuration went smoothly.
Got the massage:
Your 3CX Installation -----.my3cx.at is ready
You can access the 3CX Management console from this URL: ---- or via IP: ----
Got all the credentials.
But when I try to access the WebUI, it wont work, no access, i tried both URL and IP, nothing.
Somebody got any ideas?
Thank you!
In order to access the UI there needs to be a network path to it. So if something like a firewall is blocking you, it will not be reachable.
Try the following: use a PC that is on the same subnet as the Pi. Then type https://youPiLocalAddress:5001
This is assuming you left the default ports. if you changed them, replace 5001 accordingly
Reactions: GeeF0rce
Reactions: GeeF0rce
I would make sure your ip for your pi3 has not changed as well.
@aws2p ,
Thanks for the tip, my ports were not correctly configured, works like a charm now! :)
Kayla Norris
