Solved Can't add an IP to BLACK LIST
BABALUCHA
Hello Everyone
I m trying to add an IP to the Black List but it bounces back with error saying that IP is allready in the Black List but i don't see that IP in the list,Please see pic attahced.Thanks for stopping by and your help.
It may not have been manually added by you but it exists in 3CX's Global IP blacklist(enabled in Settings >> Security) and that is why you are receiving that message.
Reactions: BABALUCHA
Hello ChrisC
Thanks for your help , but i dont see or locate Global Blacklist under SETTINGS.
It seems you are running 3CX v18.
You should be able to find the setting under "Security(Left Menu bar) >> Anti-Hacking".
Ok ChrisC i found it .So i guess by enabling (default) we are saying that we will ues the GLOBAL BLACK LIST that is behind the scene and secure the PBX......Ok got it.
Reactions: ChrisC_3CX
That is exactly right, having 3CX's Global IP Blacklist will give your 3CX Instance access to a list of IPs known to be fraudulent and blocks them before they even come in contact with the PBX. The best part is that the list gets dynamically updated so you're always protected.
Thank u so much for your help and time :)
You're very welcome!;)
Please feel free to start a new thread should you need anything else!
devo.it
