Solved can't do outbound calls
Dan Nica
I have installed a 3CX PBX on-prem/linux for a demo (free license) and would like to use it with SIPTRUNK provider (demo account). I added the siptrunk sip trunk, I see it green, added a group and put all the extensions in it with default setup, created an outbound rule abd allow the group to use siptrunk route.
Installed the android client on two phone and can make calls between extensions, but I cannot dial outside (tried us48/canda), I always get a "Not Found" error.
LE: the android phones are not on the same IP network as the PBX, I can provide debug logs
Any help much appreciate.
Look at the activity log, and see what the number is being passed thru to the sip provider - it may not be in the correct format.
Also the activity log will should you, if it is using the correct outbound rule
this is my first error in the logs
01/07/2019 4:00:13 PM - Call to T:Line:10000>>623#######@[Dev:sip:427#####@gw1.siptrunk.com:5060] from L:7.1[Extn:112] failed, cause: Cause: 404 Not Found/INVITE from 63.247.69.226:5060
623####### is a 10 digit US truncated number and 427##### is my 8 digit siptrunk # and
112 is my extension
Hello @Dan Nica ,
The provider you mention does not prepend any digits to the dialed number. That being said you will be required to dial the full number for the call to go through. For North American it will need to be an 11 digit number so try adding 1. In other words, dial 1623#######. If this works for you then you might want to consider prepending the digit 1 in your outbound rule instead of manually adding it to the dialed number each time.
You can check our guide on the specific provider, please find the link below:
https://www.3cx.com/docs/us-sip-trunk-sipus/#h.svzc8umtd4iq
Scroll down for the Outbound Rule guide.
Please let us know if any further clarification is required.
this is works great, anyway I have to make several outbound rules to route different destinations
thank you
thank you
Hello @Dan Nica ,
Glad to hear you got it working. Please don't hesitate to contact us if any further clarification is required.
jlucero
