Can't factory reset T48S
kinetic4
I have a Yealink T48S that I need to reset but can't. The OK button seems to work fine for other things but when I hold it down for a long time to get a factory reset the message to reset never comes up. Also, I don't know the client password to login with the browser. The firmware is 66.81.0.103. What can I do to reset?
  • Press and hold Speaker button
  • Turn phone off and on with speaker button held down until you see IP details
  • When you see IP details press OK - It will say starting update (dont wait)
  • Restart the phone again as normal
  • Use GUI to update FW with default details
Thanks, that helps me make some progress. On the 2nd step, when the phone comes back on; I have the choice of TFTP or USB.
When I select TFTP I can change the IP address info which is progress but the phone still comes back up otherwise configured as before. The IP is changed but I still haven't factory reset the phone and I can't get into it.
is this phone configured on your existing system or another?
I see now, I have to get the proper files, setup a tftp server and restore it that way, right?
yes this is correct. I use PumpKIN TFTP and is easy to use. Just a few tips if you have never used it before. Once installed, create a folder on your c:\ drive called TFTP. Open the program and click on options. Set your settings as below and put your files in the c:\tftp directory. Find your IP of you PC and then use that on the phone for TFTP server IP.
14088
Excellent, thanks. I'll let you know how it goes.
I won't be getting this done right away. I've not found the .bin and .rfs files for download so I've submitted a ticket to Yealink, they have an announcement on their website that they are closed until Feb 1 for the Chinese new year.
I take this opportunity to ask you guys if you know another wait to contact Yealink other than mail or Chinese number x)
This is so frustrating. They changed their return date from Feb 1st to Feb 10th but then they responded on the 4th. They say I need to get the files from the "phone provider". I could do the TFTP update procedure but it seems I'm stuck without those two files.
And your phone provider is unable to help you ?
Guriqbal Singh
