Can't get a phone to register
HMC-Brad
Trial User
Hi All,
I could really use some help. I have spent Hours upon Hours trying to fix this.
Issue: Both Yealink T42G and Fanvil H2U phones will not register
What i have done:
I have tried the 3CX Free version, new install
I have tried the 3CX Pro version, new install
I have disabled "Block Remote non-tunnel connections."
I have "Use Unsupported Firmware" (just to verify it's not that"
I have a Fortinet Firewall at the Office with SIP ALG disabled.
Firewall Logs show ACK and SYN, so I know traffic from phones is getting out
Looks to be an issue with the cloud 3CX server, but 3CX Event logs don't show anything at all, other than a blacklist since it was failing to register (i turned it into an allow for 30 days)
I could really use some help here, thanks!
Hi, could you please clarify exactly which phone models and firmware versions you have? Also, are you using them behind a 3CX SBC?
Thank you so much for taking the time to assist, we would like to get this deploy to our hotels soon, im at the testing phase and cant get past registering the phones, so i appreciate your help! Sorry i had a typo on the model, right now im trying with a Yealink T42G using firmware: 29.83.0.145 We arent behind a SBC
Let's get through some basics -
Is the Firewall Checker on the PBX dashboard showing green? If not, run it and fix any issues that shows.
Is the SBC showing correct registration to the PBX?
Were the phones set to connect to the PBX via this up-and-running SBC?
Thanks,
KS
This is your problem given it’s a “cloud” server.
From the Yealink 4 docs, “Yealink T41P, T42G, T46G and T48G are end of life. Follow this guide.” …though tbf the guide page is blank for me [edit: it's showing now]. I recommend a newer phone.
Hi All,
So this is a cloud server, Firewall test OK: SUCCESS.
I'm not running a SBC, I was told that i don't need a SBC if the phone supports 3CX, is that incorrect?
Hi All,
Cloud=SBC... You always need an sbc if the phone isnt local to the pbx.
am i able to deploy multiple SBC's, we have 4 locations. so we need 4 SBCs? one at each site i would assume?
Correct, thats the way to go.
or use router phones including SBC feature
Reactions: bitn2
Hi HMC-Brad, footnote for 'clarity' in case it is helpful at all?
with a standard 'modern' cloud 3cx deployment
3cx will require either SBC proxy to facilitate connections for phone handset hardware
or
you will need at least one modern phone handset with built-in proxy function - a so-called 'router phone'
broadly speaking - the 'better' option will depend on your site size and 'preference'
if a site is ~relatively modest (ie, not a lot of handset) then possibly a router phone as your proxy is fine.
note inherently this config means that if the router phone device is offline / unplugged // then all your other phone handsets at this site are also offline.
if the site is not so small, or you do not with that dependency to exist (ie, all phones depend on one phone being alive to work)
then deploy an SBC will be the better pick. You can then locate the SBC in a 'secure location' (network closet, server room, etc) so that end-users don't have the option of "hey, I will unplug this thing now because I feel like it" - which might make life easier for you.
note that a 3cx SBC is not a demanding function - you can run it on a standard "MiniPC" or an 'entry level server' and some people deploy them using Pi hardware I believe. Given the modest cost of 'standard' mini PC boxes these days (ie, you can get something pretty solid for ~$200) - that path has been my own preference - it means you have a 'very standard x86 computer box, with a normal monitor keyboard mouse hookup, no custom parts needed, etc - 'it just works'.. Alternately if you have a site with on-prem virtualization server, you can easily spin up a 3cx SBC VM on ~any standard virtualization platform (ie, full hardware virtualization - KVM based / VMWare / Xen / Whatever).. Again, the requirements of the SBC are modest so a ~pretty basic VM will do the trick (ie, 2Gb ram, 1 vCPU, 10gb disk - single LAN NIC - approx).
presumably you are looking at using older hardware because maybe? you have such parts from a prior voip project or something like that. This is "OK" for deployment, especially if the phones are listed as "work ok" with 3cx. I've deployed a number of different older phones over the years, and generally 'they work fine'. If you have less-supported phones that you choose to use, it might mean more work with deployment and config management long term. If you plan to 'deploy and forget' the handsets this might be a non-issue. (ie, "EXT 200" will be "room 200" and this will never change during the life cycle of the handset > possibly means you don't care if elegant provision config management features are broken or not available?)
You might want to do nice simple deploy path
1) have a clean 3cx cloud deployed server lit up and alive / base config in place.
2) do some test calls / connectivity via web-client first
3) deploy an on-prem SBC at your 'test site' and then boot up a phone handset <> so it becomes visible in 3cx after booting up while in same LAN as your SBC
4) test calls with that handset
5) rinse and repeat the process, spin up your different handset model, make sure it works as expected. Keep notes about what you are doing / what does/not work.
6) once you have a standard process for deployment well tested & understood, it is easy to fan out and add more SBC/Sites and more handsets as needed.
good luck with your deployment.
Tim
How you go about it partly depends on how many devices need to connect to 3CX from each location.
A router phone is one solution that works well.
I've also seen several setups where customers find some machine that is "always-on", and deploy a 3CXSBC - the linux version - in a small VM. It's not the most elegant, but it's a cost-free way to perform a proof-of-concept before getting a small dedicated machine for the task, if you have a larger number of phones that need to use the SBC.
ARKC
