can't install sbc on rapberry pi....
lhblhb
Forum User
Hi, followed these instructions....
https://www.3cx.com/docs/installing-pbx-raspberry-pi/
But when I get to running..... wget http://downloads-global.3cx.com/downloads/sbc/3cxsbc.zip -O- | sudo bash
I get the error.....
Resolving downloads-global.3cx.com (downloads-global.3cx.com)... 104.18.15.54, 104.18.14.54, 2606:4700::6812:e36, ...
Connecting to downloads-global.3cx.com (downloads-global.3cx.com)|104.18.15.54|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2023-01-09 11:47:55 ERROR 404: Not Found.
-bash: .: filename argument required
.: usage: . filename [arguments]
Any ideas please?
Are you copying and pasting the command in to putty?
Hi, thanks, yes it was, oddly I found the same link on another site and copy paste worked from that site....
Although still didn't work, just surprised that 3cx haven't updated the pi sbc script to work with the latest pi os version (bullseye) (been out for a long while), only works on buster, have to either use a different pi with older image as i'm running other things on this pi :(
Can you paste the working link. I am getting an error using the guide provided above from 3CX
I get the following error
2023-01-09 15:31:35 (8.23 MB/s) - written to stdout [26298/26298]
Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
OK
connecting https://1142.3cx.cloud
Ign:1 http://downloads-global.3cx.com/downloads/debian bullseye InRelease
Err:2 http://downloads-global.3cx.com/downloads/debian bullseye Release
404 Not Found [IP: 104.18.15.54 80]
Reading package lists... Done
E: The repository 'http://downloads-global.3cx.com/downloads/debian bullseye Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
error: Cannot install the 3cxsbc package
No to avoid confusion Bullseye isn't supported - that link is the the correct Buster download.
But there is an error with the below SBC link as mentioned in the 3CX instructions. This was working but just recently the below link does not work
wget https://downloads-global.3cx.com/downloads/sbc/3cxsbc.zip -O- | sudo bash
What I've had to resort to doing is download the 3cxsbc.zip file first using the link
Once you have the file downloaded into the Raspberry Pi download folder it then Terminal into the Downloads folder and then
sudo bash 3cxsbc.zip
It then works and installs properly - I have no idea why this has stopped working but this is my current workaround.
FOLIT
