Can't receive phone calls in a ring group
jayf
New User
Issue I'm having is my phone does not ring even though I'm listed in a phone group. Everyone else's phone rings but not mine. I'm not too sure on what to do here. Any suggestions?
Hi @jayf
When you say 'my phone does not ring', you mean your mobile number or the 3CX Mobile App?
If you mean you mobile number, as a first step please check if you have configured a mobile number in your extension and then that the option 'Also ring my mobile' is enabled in the Settings >> Status section of your extension.
In case that you mean the 3CX Mobile App, check for the option 'Accept PUSH notifications' to be enabled in in the Settings >> Status section of your extension.
Reactions: TheodorosG_3CX
RJenkinsROCK
