  • V20 Update 10 Final Learn more
Cant receive phone calls to GrandStream GXP1620,FW version not supported
danagt
Hi, I have added GrandStream GXP1620 to extension and in 3cx admin "Phones" it shows up in red colour: Fw version Not supported 1.0.7.6.
It looks like the lastest version is not supported to complete phone provisioning and I need 1.0.7.3 version instead. I assume IP phone is not provisioned thats why I dont get calls but it goes directly to extension's voicemail. Please advice what to do. Is it possible to downgrade to 1.0.7.3? How difficult it is?
Yes, latest 3CX supported firmware is 1.0.7.3 so if your phone is at a higher level it may not work properly , to Downgrade phone FW ask on GS forum or support.
You can safely downgrade this phone to the supported firmware via 3CX Firmware button. No restrictions were applied on that firmware.
If the extension shows a red dot, then most likely the provisioning and/or registration failed.
So firstly make sure the device is able to provision after a factory reset by following this:
https://www.3cx.com/sip-phones/grandstream-gxp16-series/
Hint: If it is a STUN phone it should boot up and ask for user/pass after successfully resetting it, this is a good sign
BConveryCoreCare
