Can't save any changes to Trunk settings
Foiler-NZ
I first noticed that I could not add a new DID to our Trunk .. clicking OK takes you to the Options Tab and clicking OK there does not close and exit from the Edits of the Trunk.
On further investigation, no changes at all are possible to the Trunk settings, in every case the same thing happens, you get taken to the Options Tab and none of the changes can be made to stick.
From what I have read, this indicates a problem with the Trunk - which is otherwise working perfectly.
I created a new dummy trunk with similar basic settings but with a different Authentication ID to allow me to create it. This trunk does not register because of the deliberate wrong credentials, but it does allow to make edits.
Are there any tricks I can make to the original Trunk to "repair" and allow it to be edited - thus avoiding extensive re-configuring in the case of a new Trunk?
Our 3CX is Linux latest build 18.0 build 418.
There's probably a config error somewhere and it prevents you from saving any changes. Have you checked if the Options tab had any field with red warning on it?
There are no red warnings in any of the tabs of the Trunk setup.
VR46
