Cant save phone provisioning tab - no errors showing
alex22alex
SOHO User
I am trying to assign yealink T42* to an extension. It has the latest firmware and has been reset. When i try to assign it to the extension it takes me to the provisioning tab but i cant get it to save the extension pressing the OK button does nothing and there is no obvious error message.
https://drive.google.com/file/d/1e4cjjK2aThls2QR5s7ZamVW77yO9FqZw/view
Interestingly the same thing happens when trying to change the provisioning just to the 3cx soft client for a different extension
https://drive.google.com/file/d/190IcTTqR1JCbnhizRG35qfHDTSvjKpLF/view
So probably not actually to do with the phone
Also the yealink now seems to be a state where despite not working its somehow blocking self from 3cx
What version of 3CX are you running ?
Have you tried using a different browser and clearing the cache ?
Upgrade to V16 today - Chrome latest version also now tested in Safari and cleared caches so not a browser issue.
These extensions i am trying to allocate to have an error like this however even when i change all the passwords to meet the criteria nothing happens could this be linked ?
Just for anyone else with this it seems the error here is poor UI if you encounter this message changing the individual three passwords mentioned doesn't seem to clear the error.
You have to use the regenerate functionality on extension list screen to get rid of it.
Hi @alex22alex
What happen if you try to create a brand new extension and provision the phone on it ?
Have you tried to reboot the 3CX Server ?
Passwords on extension are a bit shitty imo. That's why the best way is to regenerate and send welcome email to get them :)
yep this works thanks for the debugging and support !
You're welcome ;)
Hi Alex,
In the general tab you would see the error, even though this was not in your video.
Please regenerate the passwords via the management console otherwise you cannot save because the password does not meet the requirements.
[email protected].
