Solved Can't send SMS through Flowroute but can respond to SMS
Frank86
About a month ago, after upgrading to V18 U6, I set up SMS and MMS web hooks in Flowroute and was able to send and receive SMS messages through my 3CX numbers. All was good.
Now, I can successfully respond to SMS messages sent to my 3CX numbers, but if I send a new message to the same external numbers, my messages show up in 3CX with a red x and don't go out.
Why would that be?
Check that your access key and secret key are correct in the 3CX trunk settings. If they are and you still cannot send SMS then I would recommend contacting Flowroute support for assistance.
Check my thread, could be related.
I just had to change the Flowroute DID configuration from *1(number) to the E164 format +1(number)
Reactions: YiannisH_3CX
rsaldin@advancedbrainspin
