Solved can't update 3xz Hosted VM from 16.0.6.655 to 16.0.7.1078
blueshield
Hi All,
Any help is appreaciated. i.ve been trying to update the 3CX Debian 9 install to ver 7 - 16.0.7.1078 which is avaiable in the updates, but selecting it to download and it just revert back to login prompt and nothing happend.
the auto installation over the weekend did work either.
Code:
--2021-03-21 14:26:05--  https://downloads-au.3cx.com/downloads/v160/debianupdate/stretch.txt
Resolving downloads-au.3cx.com (downloads-au.3cx.com)... 35.201.76.132
Connecting to downloads-au.3cx.com (downloads-au.3cx.com)|35.201.76.132|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 23467 (23K) [text/plain]
Saving to: ‘/tmp/pinning.tmp’
     0K .......... .......... ..                              100% 4.36M=0.005s
2021-03-21 14:26:05 (4.36 MB/s) - ‘/tmp/pinning.tmp’ saved [23467/23467]
Pin file downloaded
Hit:1 http://downloads-global.3cx.com/downloads/debian stretch-testing InRelease
Hit:2 http://security.debian.org stable/updates InRelease
Hit:3 http://ftp.debian.org/debian stretch-backports InRelease
Hit:4 http://ftp.au.debian.org/debian stable InRelease
Hit:5 http://ftp.au.debian.org/debian stable-updates InRelease
Hit:6 http://downloads-global.3cx.com/downloads/debian stretch InRelease
Reading package lists...
No updates installed.
tried the troubleshoot -
https://www.3cx.com/community/threa...16-0-7-1078-unmet-dependencies-problem.78083/
wget -O - https://downloads.3cx.com/downloads/misc/debianpatches/9/16/0/5/20200619-os-update.sh | bash
sudo apt-get clean
sudo apt-get install -f
sudo dpkg --configure -a
but still no luck.
PS: Free space is 7GB and recently updated hte license key from std to professional.
Thanks in Advance!
Maddy
Could you tell us where the instance is running?
Hi stefan,
It's on premises, vm on Vmware.
sorry I put the hosted in hurry.
Did you get an email informing you that the upgrade was not successful?
Check that your email is listed here:
Code:
Hit:2 http://ftp.au.debian.org/debian stable InRelease
Hit:3 http://ftp.au.debian.org/debian stable-updates InRelease
Hit:4 http://downloads-global.3cx.com/downloads/debian stretch InRelease
Hit:5 http://ftp.debian.org/debian stretch-backports InRelease
Hit:6 http://security.debian.org stable/updates InRelease
Building dependency tree...
Reading state information...
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 3cxpbx : Depends: libfreeimage3 but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Rollback to 16.0.6.655...
3cxpbx is already the newest version (16.0.6.655).
The following packages were automatically installed and are no longer required:
  libcurl3 libunwind8 linux-image-4.9.0-6-amd64 tcpd
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 128 not upgraded.
Based on the above, it looks like the upgrade is failing due to some Linux packages not being upgradable. This can sometimes happen if you manually upgraded something to a version we do not support, and some 3CX packages can no longer be applied, or if the repositories were modified at some point .
I would recommend that you take a full 3CX backup, then recreate a fresh VM and install again using our latest ISO https://www.3cx.com/docs/manual/installing-debian-linux-pbx/
Thanks John_S, downloaded the latest backup and restored using cmd udirng fresh installation. all good :) thanks for the prompt reply and guidance.
Kayla Norris
