CDR - Live View with Call Details & Costs, VoIP Trunk Charges & Simultaneous Call Analysis
Cjay
Latest update [v2.6, Dec 9th, 2018] adds to the features:
  • A near real-time display of call details as they are completed.
  • Overview of PBX call activity with summaries of total calls made in different timeframes.
  • Exact cost of calls displayed using most common charging methods including call duration, fixed cost per call, rounding duration and minimum call cost or duration.
  • Running total of call costs for each 3CX trunk [usually outgoing to a VoIP provider]. Value displayed either as an account balance or as the cost of the calls made since a user selected date.
  • Filtering, extraction & viewing of call details & export to Excel for further reporting.
  • Ability to apply charges to internal (extension to extension), bridged 3CX calls or other fixed length dial strings if desired.
  • Maximum simultaneous call count calculator.
  • Archiving of 3CX CDR’s into daily or monthly files.
  • Data backup with auto rollback & restoration from CDR’s in event of PC problems.
  • Works with 3CX system running under either Windows or Debian operating systems.
  • All this achieved without any ‘hooks’ into 3CX internals – only uses Call Data Records [CDRs].
open
open
If you want to take a look and try it the documentation and install files are here:
https://drive.google.com/open?id=1u5FCXOYDouODivjz1kj3OsNmyaRcKP9Y
Recently there seem to have been quite a few posts regarding Call Data Records [CDRs] and how to use them, it would seem from users who need just that little bit more information out of their 3CX system.
I have been using 3CX for over 10 years now. It's amazing software but I too always wanted a little bit more... So after much tinkering around I created a program called CallSequitur to meet my needs. Now I'm only a hobbyist, certainly not a software developer, so my skills and resources are somewhat limited - but I thought it might possibly help the 3CX community at large! What it offers is:
  • Live processing of CDRs
  • Near real-time display of calls made with to/from details & exact call costs
  • Cost of calls on a per trunk/provider basis, with ability to show either as an account balance or as the total cost since some date.
  • Simultaneous Call analysis - To show this all important figure
  • Plus more, but it's all in the guide I've written...
If you want to take a look and try it out I have put the documentation and install files here:
[but the software is Windows only for now]
Minor update just uploaded:
Added Excel report template + Option to turn on logging (mostly to do with the upcoming DST changes)
Reactions: YiannisH_3CX
Edited original post to add details of new version now supporting the inbuilt 3CX CDR service.
Great work Cjay, easily installed and working in our environment. Call Costs can now be reported on using fixed call costs rather than being limited to timed calls in 3CX reporting. The Sim Call Analysis feature is a nice edition allowing us to license effectively. Thanks for your time and effort and sharing with our community. I'm sure many others will find this a very handy utility.
I've just updated this CDR software & documentation to a new version which adds configurable timeframes to the Call Volume statistics & Simultaneous Call analysis. The new version [v2.5] can be installed over any existing version without data loss. Link to software/documentation is as before:
A new update to my CDR processing software is available. Added new features including:
  • Archiving of CDRs into daily or monthly files
  • Ability to charge based on fixed length number ranges
  • Daily backup [& auto restore from CDR archive if needed]
  • Other function enhancements
Original posting above shows download link, full feature list & screenshot.
zipman
