Solved Certificate not renewing
WNY-Brian
Came in this morning to find the certificate had not updated.
Self Hosted 18.0 (Build 35)
su phonesystem
/usr/lib/3cxpbx/PbxConfigTool -vvv --renew-certificates
_____ _______ __
|__ // ____/ |/ /
/_ </ / | /
___/ / /___ / |
/____/\____//_/|_|
Welcome to the 3CX Configuration Tool
Help https://www.3cx.com/docs/manual/
That is the only output
cat PbxConfigToolRenewCertificates.log shows no new entries after 7:30 this morning (over an hour ago), even though I have tried it again since then.
Anyone know if there is a resolution?
Reactions: WNY-Brian
Reactions: bitn2
The certificates start the update process a month out before expiry. If it fails one night, see if it renews the next day. It could be a minor glitch in the renewal process on that particular day.
If it fails on multiple days then you should start the investigation as to why this is happening.
hpgitsupport
