Solved CFD App is not registered
Farkhad1597
Hello
I have two 3cx Servers in failover mode.On first 3CX i had Call flow app and i uploaded project successfully, but on second 3cx server i cant upload cfd, it shows CFD App is not registered but the script is correct. CFD app was taken from backup of first server
This is probably because your "passive system" has most of it's services stopped due to you having faiolver enabled and having set it as as Passive.
If the Active/Primary server fails and the Passive/Secondary ones come online, then the CFDs should register.
My passive server is in active state right now and my callflow server services are also in running state. Could you help me?
Are both PBX on the same version?
Definitely just moved across from one to the other?
You didnt open it or save it in the v18 CFD did you?
i have CFD on my computer i just rebuild the project and uploaded manually. it didn't work as well
Can you check what version of CFD you built with as v18 wont work with v16
(Help > About)
(Help > About)
cfd version is 16.6.53.0 and pbx version is 16. it woks on first server but doesnt work on second
OK, to start with, could you please confirm that your license key is either a Pro or an Enterprise?
[EDIT]
Also please send me your FQDN in a PM. I am assuming due to failover being configured, both your installations have been installed with the same License Key right?
i have ENT license key
Yes both license key are the same
How i can register cfd app in 3cx? Do you know that?
All you should need to do is upload the file, that's it.
Also i want to say that my 3cx is not allowed go to the internet
This actually might be causing the problem. If you 3CX server has not activated in a while by contacting activation.3cx.com, then it might be in a "limbo" state, so some features may have been disabled.
Re-connect internet access temporarily, go to Settings --> License and press the "Refresh License Key Information" button.
Once you do this, restart all 3CX Service (while it is still connected to the internet), then try the Call Flow App again.
If this fails, send me the FQDN in a PM as I asked to confirm it correctly contacted our activation server and we could take it from there.
Reactions: jed and Evolute IT
But both servers are not allowed to go to the internet..and call flow project worked on first one..
So your only test is to put it on the internet and see if it works. I dont think support would be interested in making an ymore suggestions until this has been done.
So your only test is to put it on the internet and see if it works. I dont think support would be interested in making an ymore suggestions until this has been done.i
I gave access 3cx to internet, and it worked.thank you very much
apbGroup
