CFD Count http json response data
Goga
Titanium Partner
I am working on 3cx CFD dialer where I am using http Request component to get data , i want to do array count for below data so i can start the loop to make calls.
JSON:
    "status": 1,
    "dbresponse": [
            "name": "123456",
            "mobile": "9235363738",
            "name": "6789",
            "mobile": "0282829272",
            "name": "837373",
            "mobile": "2638378333",
    "status_code": 200
Now I want to count dbresponse array elements , like for above response it is 3 , I cannot find any CFD component apart from Execute C#code, but I am not sure how to do that.
I tried below code but it is not working.
C#:
var test = JObject.Parse (jresponse);
JArray items = (JArray)test["dbresponse"];
int length = items.Count;
return length
tried above code but it is not working.
You need to use NewtonsoftJson.
Your C# will need to deserialize, then set a variable to the count and another to 0, increment in a loop until current < count.
I tried using Newtonsoft,json, it didn't work and show error.
Please see attached snap.
The Execute C# Code component doesn't accept "using" statements. You will need to use the full type names including the namespace if you want to go that way. Other option is that you use the Execute C# File instead. In this component you include a C# file in your project, which will include the class and the method, so you can use the using statement there. For example, you can use this C# code in your file:
C#:
using Newtonsoft.Json;
using Newtonsoft.Json.Linq;
public class MyParser
    public int GetCount(string jresponse)
        var test = JObject.Parse(jresponse);
        return items.Count;
Then, you invoke this as follows:
Reactions: Goga and Evolute IT
arming
