CFD design for Predictive Dialer with Rest API option to download csv file
ybello
Platinum Partner
I am trying to initiate outbound calls from a JSON response gotten from an endpoint.
I have split the process into two flows as follows:
1. The first flow calls the Webservice which returns a json response. The flow has a C# component that writes a .csv file to the system. The C# code used is shown below (i am using the output from the webservice as input parameter (jsonInput):
using Newtonsoft.Json;​
using System;​
using System.Collections.Generic;​
using System.IO;​
public class Program​
public string Main(string jsonInput)​
// Parse JSON array​
List<string> numbers = JsonConvert.DeserializeObject<List<string>>(jsonInput);​
// Generate unique CSV file path with date and time​
string dateTimeString = DateTime.Now.ToString("yyyyMMdd_HHmmss");​
string csvFilePath = $"numbers_{dateTimeString}.csv";​
// Write to CSV file​
WriteToCsv(numbers, csvFilePath);​
// Return the CSV file path​
return csvFilePath;​
private void WriteToCsv(List<string> data, string filePath)​
// Write data to CSV file​
using (StreamWriter writer = new StreamWriter(filePath))​
foreach (string item in data)​
writer.WriteLine(item);​
2. A 2nd flow will read the .csv file and proceed with the Autodialer as normal.
The issue is with the first flow as it fails when i compile and upload to 3CX with multiple syntax errors.
Will appreciate a second look at this from anyone please.
Thank you.
Just use one flow that takes the data directly? Why write a CSV? You can use the JSON response and parse it.
Hello @ybello,
If you want a simpler solution, you can try SIP Caller, a cloud based outbound call dialer which seamlessly integrates with 3CX, and you can have working in 5 minutes. With SIP Caller you will get out of the box detailed call reports, summarized call reports, answering machine detection, and much more.
You can give it a try for free, contact me if you need additional information.
Reactions: OlegR_3CX
Can you share more light please? How do I reiterate through all the numbers?
Use a loop and a C# script to grab the entry from the Json. Use Newtonsoft.Json to deserialize the data in that same script.
vtschand
