CFD - Routing based on logged-in extensions
james_tech
Hi all,
I am looking to create a CFD based on a Q. I would like to achieve if no one is logged into the Q, then choose a different path to the current failover destination.
IF 1 person or less is logged in then route to extension 200
IF 2 or more logged in then continue to the Q
Please can someone offer some assistance?
GetQueueExtensions will be your friend!
Reactions: David_O
I have used this, but not sure what the next step would be? I am assuming a condition but what would be the condition string?
You'd use the list of extensions returned to calculate a condition like:
GREATER_THAN(GET_ITEM_COUNT(component.ExtensionList), 2)
Which would be: if extensions list has more than 2 items (2 exts), then use the transfer component to send the call to either destination.
Thanks, I am getting this error on the Call Flow logs:
Error executing last component: System.FormatException: String 'GREATER_THAN(GET_ITEM_COUNT(GetMotorwayQAgents.ExtensionNumberList), 2)' was not recognized as a valid Boolean.
You put it as a string with quotes. Remove the quotes but also check in the Expression Builder that I wrote the right function names lol
Where would I put my Q though? GetMotorwayQAgents.ExtensionNumberList
Yes and in the GetQueueExtension there's a property to set the queue number to check.
Sorry, but where am I looking? Can you adjust the code to fit our variable name please as I am getting confused lol
It should look like this in the expression builder:
And like this in the field (notice the quotes aren't there, so it is not considered a "string" but an expression) :
sdutz
