- Joined
- Dec 18, 2020
- Messages
- 15
- Reaction score
- 5
Hey
I'm working on a CFD project with a custom CRM integration. One of my lookup scenarios is not being recognised, although others are.
In CFD I'm using the Accounts Free Query lookup and passing a JSON string through to CRM. The logs show this as:
In my CRM component I have this scenario defined:
But when the request is executed, the logs show the scenario as not present:
Is it fair to assume that the scenario is being completely not recognised or can a failure in the scenario execution itself present this kind of log entry?
Code:
Start executing component with EntityType='Accounts' - QueryType='LookupFreeQuery'
XML:
<Scenario Id="LookupFromCFD_Accounts_LookupFreeQuery" Type="REST">
Code:
2020/12/31 11:20:06.739|691|0014|Err|Exception during lookup from Call Flow Designer: System.InvalidOperationException: Sequence contains no matching element
at System.Linq.ThrowHelper.ThrowNoMatchException()
at System.Linq.Enumerable.Single[TSource](IEnumerable`1 source, Func`2 predicate)
at CrmIntegration.CrmProcessor.LookupFromCallFlowDesigner(EntityTypes entityType, CFDQueryTypes cfdQueryType, String data, CancellationToken token)
