Change address of SBC on 3cx Server
MICRpro
I've setup my new SBC, but it picked up a DHCP address. I was able to change the address on the debian os - no problem. But now I can't change the address on the 3CX server under voice and chat.
These two fields are not editable. So how do I change the IP addresses?
You don't need to change that, and you can't. The data is transmitted by the SBC. Is it showing up as connected?
oh wait... why is the puplic ip the same like the lokal ip?
Reactions: JohnS_3CX
Well his PBX and SBC are on the same LAN (an assumption, but not an unlikely one).. Now, if this is an SBC being prepared to be dispatched to a remote office, then that's fine, it should clean up after itself once it gets deployed.
@MICRpro - did you restart the SBC after the IP change?
Eventually it changed to the right IP address, just a bit slow. Thanks!
Reactions: KyriacosS_3CX
Carlos - EC Mates
