Change Caller ID extension number in extension-to-extension call
Big George
Hi all,
there is a way to present a differend caler-ID when one extension call another extension?
Use case:
- I have one extension number used on my desk phone, ex: 201. => this extension is public (know by all my collegues)
- I have another extension number used on my App, ex: 501 => this extension is "private" (nobody know that them exist)
- I use the "forwarding call" function set on desk phone: "when I'm DND forward call to 501".
Then, now I want to call my collegues using my App (501) but my collegues need to see "calling from 201" (in order to mantain "unknow" the 501 extension)
Thank you
This question came up not that long ago, with regards to ring groups (changing the caller ID to the RG number), and the consensus was that , no, you cannot change your caller ID internally
You might be able to do some jiggery pokery by using a loop trunk, but the consequences won't be desirable for other (outside) calls you make, along with using two licences per call. So, not really practical.
[email protected].
