Change Extension Number
therz
Is there a way to change the "extension number" after the users have been imported from O365?
Or is there a way to maintain the "extension number" at the user in O365 or Azure before importing?
Hello Saqqara,
thanks for the quick answer.
Then the importer of O365 is unfortunately not usable, if I cannot determine the extension number and I cannot change the number afterwards.
jsbjsb
