Change START_TIME in Missing Call Template
Marcel Junk
Hi Guy,
we receive Missing Calls in this Format: 2018-Nov-15 16:39:19
so i think it : yyyy/MM/dd HH:mm:ss
i want to change to : HH:mm:ss dd/mm/yyyy
I see a Option in Settings -> Parameter -> MISSEDCALLSDATETIMEFORMAT -> i change this to HH:mm:ss dd/mm/yyyy but it dont change something in the Mail.
Is there a Other Solution for this?
Best Regards,
Marcel
I've never changed that setting but typically those settings are cached so you would need to restart at least the management console service (if not others) for it to read the change.
Hello @Marcel Junk
I would recommend not changing anything in the Parameters section of the PBX and instead changing the Regional settings on your machine. You will then need to restart the machine to apply the change.
hmm... okay... but with both i dont have succes... i change on linux the locate to de_DE.
Ist look Okay, but the Time in the Mails are not changed.
Best Regards,
Marcel
LANG=de_DE.UTF-8
LANGUAGE=
LC_CTYPE="de_DE.UTF-8"
LC_NUMERIC="de_DE.UTF-8"
LC_TIME="de_DE.UTF-8"
LC_COLLATE="de_DE.UTF-8"
LC_MONETARY="de_DE.UTF-8"
LC_MESSAGES="de_DE.UTF-8"
LC_PAPER="de_DE.UTF-8"
LC_NAME="de_DE.UTF-8"
LC_ADDRESS="de_DE.UTF-8"
LC_TELEPHONE="de_DE.UTF-8"
LC_MEASUREMENT="de_DE.UTF-8"
LC_IDENTIFICATION="de_DE.UTF-8"
LC_ALL=
RemyDijke
