Change the operator extention from default extention number to another extention.
Elil_TeleProTech
even there is no DID pointed to my 3CX, still receing miss call or voice mail, unregistered extention calls also reaching 100 extention,
I noticed 100 as default extention for admin access, still getting misscalls and voice mail.
then changed >Advance - > Paramerter -> search for the opertaor and change 100 to correct extention number,
hope it will be ok, if any one have any comment let me know.
You can actually do this from under the admin console > System > Voicemail section.
Thank you, let me see.
normally when we install first time 3cx we get 100 extention as main number. but we use to create 600 or 700 as reception.
100 only for our admin access for remote support. but we notice some calls to 100 as miss call or voice mail. look like fail over something.
that why I want those call to go what ever operator extention. so I changing operator parameter and voice mail transfer.
let see change above with two three customers and try.
Thank you
Regards
Elil
TeleProTech Solutions
You are overcomplicating things when there is a setting. That is the setting that changes the parameter.
Reactions: Charles_3CX
got it , let me avoid that. Thank you
SCarpenter@fifthavenue-la
