Change time of auto update
mohamadkaddoura
We know that the system doesn't allow to disable automatic updates for hosted 3CX systems. But we need to be able to change the automatic update time. Is this possible? On my side I can neither disable nor change the time at which the automatic updates should occur.
Hi there.
No, this will not be possible, and you can't disable this option too.
Hi there.
Will this be changed in any future update? Just the part where we are able to change when the automatic update takes place?
We don't have this information for 3CX hosted, as it is fixed and shown in the console too (which is weekly on Saturday between 5-6 am). Using your own hosting should allow you to do that.
tdzski5
