changing static public ip ,DNS,Update
mohamed hamed
when i changing static public ip , 3cx still use the old one .
i put 8.8.8.8 dns-nameservers but can ping and can't netstat google.com.
update can't reach the server.
have you tried going to your 3CX network settings switching your External IP Configuration to dynamic mode?
no i just change (Enter your static public IP) to the new one
So if your modem/router/firewall has a new IP now, you just need to go to your 3CX Dashboard under
Settings > Network > Public IP Tab > External IP Configuration and change the setting from Static -> to Dynamic.
After a while your system will automatically detect the new IP and show it, then you can switch it to Static again when you are ready.
10289
i did it but still detecting ....
You can try restarting all your services now from the Dashboard, to force the detection to take place immediately.
i restarted 3cx services then reboot but still detecting ,can't reach server update.
firewall test(
Value cannot be null.
Parameter name: address
Can you tell us your full 3CX version as seen on the dashboard?
professional perpetual 15.5.15502.6
Sounds like you are having network issues, I would start by checking by network setup from the beginning, including any firewall rules, static routes etc before even touching the PBX to confirm that the computer can reach the internet successfully
fransisco
