Chat box popup
Levaz
New User
Hello, i keep getting the chatbox pop up on my site with popup disabled and cache cleared, any ideas?
Automatic Chatbox Pop-Up Disabled
Pop-up only when agents are online
The popup always popups except if that option is enabled and no agents are online. If agents are online, it will pop.
Hi @Levaz,
There should not be a popup if you've set the Automatic Chatbox Pop-Up to Disabled. Can you tell us what the pop-up prompt is saying? Is it an offline chat pop-up or is it prompting you for your name / email (dependant on what you selected under General Settings)?
SupportRock
